ONTAP EMS reference
wafl.relocating events
wafl.relocating EMS events occur when ONTAP encounters issues associated with aggregate relocation operation restrictions.
wafl.relocating.fence.fail
Severity
ERROR
This message occurs when the system cannot perform an aggregate relocation because a fence is set on one of the volumes in the aggregate. The relocation is aborted.
Corrective Action
A volume in the aggregate is currently fenced for group operations. Retry aggregate relocation after any group SnapRestore® or mirror transfers are complete. If the problem persists, contact technical support.
Syslog Message
%s %s%s%s%s has a fence set. Canceling aggregate relocation.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Unique volume identity when the volume name itself is insufficient.
wafl.relocating.iron.fail
Severity
ERROR
This message occurs when the system cannot perform an aggregate relocation because wafliron is active. The relocation is aborted.
Corrective Action
Retry aggregate relocation after wafliron is finished.
Syslog Message
%s %s%s%s%s is running vol wafliron. Canceling aggregate relocation.
wafl.relocating.sp.fail
Severity
ERROR
This message occurs when the system cannot perform an aggregate relocation because a secure purge operation is in progress on one of the volumes in the aggregate. The relocation is aborted.
Corrective Action
A volume in the aggregate is currently going through a secure purge operation. Retry aggregate relocation after this operation is complete, or after you abort the operation by using the "volume encryption secure-purge abort" command. If the problem persists, contact NetApp technical support.
Syslog Message
A secure purge operation is in progress on %s %s%s%s. Canceling aggregate relocation.
