ONTAP EMS reference
gpo.cap events
gpo.cap EMS events occur when ONTAP encounters issues associated with Group Policy Object (GPO) central access policy (CAP) settings.
gpo.CAP.applied
Severity
INFORMATIONAL
This message occurs when applying group policy object (GPO) central access policy (CAP) settings succeeds.
Corrective Action
(None).
Syslog Message
Successfully applied CAP settings to Vserver %s.
vserver (STRING): Vserver name.
gpo.CAP.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) central access policy (CAP) settings fails.
Corrective Action
Check the CIFS configuration by running the "vserver cifs show -vserver <vserver-name>" and "vserver cifs check -vserver <vserver-name>" commands. Run the job again using the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
Failed to apply CAP settings to Vserver %s failed, reason: %s.
reason (STRING): Reason for the failure.
