gpo.cap events
gpo.cap EMS events occur when ONTAP encounters issues associated with Group Policy Object (GPO) central access policy (CAP) settings.
gpo.CAP.applied
- Severity
INFORMATIONAL
- Description
This message occurs when applying group policy object (GPO) central access policy (CAP) settings succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully applied CAP settings to Vserver %s.
- Parameters
vserver (STRING): Vserver name.
gpo.CAP.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) central access policy (CAP) settings fails.
- Corrective Action
Check the CIFS configuration by running the "vserver cifs show -vserver <vserver-name>" and "vserver cifs check -vserver <vserver-name>" commands. Run the job again using the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
- Syslog Message
Failed to apply CAP settings to Vserver %s failed, reason: %s.
- Parameters
reason (STRING): Reason for the failure.
