ONTAP EMS reference
kmip2.cannot events
kmip2.cannot EMS events occur when ONTAP encounters issues associated with the KMIP2 client importing keys from Key Management Interoperability Protocol (KMIP) key servers.
kmip2.cannot.import.MROOTAK
Severity
ALERT
This message occurs when the KMIP2 client cannot import the MROOT-AK key from a Key Management Interoperability Protocol (KMIP) key server. A key was retrieved from a KMIP key server, but an error occurred when trying to add the key to ONTAP®. The node fails the boot up process when this happens.
Corrective Action
Reboot the node. If the issue persists, contact NetApp technical support for assistance.
Syslog Message
KMIP2 client fails to import MROOT-AK from KMIP key server. Error: %d.
err (INT): Error code from system call to sysctlbyname().
kmip2.cannot.import.NSE.key
Severity
ALERT
This message occurs when the KMIP2 client cannot import an NSE key from a KMIP key server. A key was retrieved from a KMIP key server, but an error occurred when trying to add the key to an ONTAP® data structure.
Corrective Action
Run the "security key-manager restore" command to restore keys from external key servers.
Syslog Message
KMIP2 client failed to import NSE key from KMIP key server, error: %d
kmip2.cannot.import.NVE.key
Severity
ALERT
This message occurs when the KMIP2 client cannot import an NVE key from a KMIP key server. A key was retrieved from a KMIP key server, but an error occurred when trying to add the key to an ONTAP® data structure.
Corrective Action
Syslog Message
KMIP2 client failed to import NVE key from KMIP key server, error: %d
kmip2.cannot.read.client.cert
Severity
ALERT
This message occurs when the client certificate cannot be read. On a Cloud ONTAP® system, this message indicates one of the following: 1) A request to create an encrypted aggregate will not succeed because the key cannot be sent to the external KMIP server, or 2) The request to retrieve a key from the external KMIP server will fail. In this case, the encrypted aggregate will not be able to be mounted. On a NSE system, this message indicates one of the following: 1) A request to re-key a NSE drive will not succeed because the key cannot be sent to the external KMIP server, or 2) The ability to read/write data to/from a NSE drive might be impacted if power to the drive or to the disk shelf is lost.
Corrective Action
Examine the KMIP client certificate and ensure that the certificate has been created properly.
Syslog Message
KMIP Failed to read client certificate with error: %s
err (STRING): KMIP error code.
kmip2.cannot.read.private.key
Severity
ALERT
This message occurs when the client private key certificate can't be read. On a Cloud ONTAP® system, this message indicates one of the following: 1) A request to create an encrypted aggregate will not succeed because the key cannot be sent to the external KMIP server, or 2) The request to retrieve a key from the external KMIP server will fail. In this case, the encrypted aggregate will not be able to be mounted. On a NSE system, this message indicates one of the following: 1) A request to re-key a NSE drive will not succeed because the key cannot be sent to the external KMIP server, or 2) The ability to read/write data to/from a NSE drive might be impacted if power to the drive or to the disk shelf is lost.
Corrective Action
Examine the KMIP client private certificate and ensure that the certificate has been created properly.
Syslog Message
KMIP Failed to read client private certificate with error: %s
