kmip2.cannot events
Creating your file...
kmip2.cannot.import.NSE.key
- Severity
ALERT
- Description
This message occurs when the KMIP2 client cannot import an NSE key from a KMIP key server. A key was retrieved from a KMIP key server, but an error occurred when trying to add the key to an ONTAP® data structure.
- Corrective Action
Run the "security key-manager restore" command to restore keys from external key servers.
- Syslog Message
KMIP2 client failed to import NSE key from KMIP key server, error: %d
- Parameters
err (INT): Error code from system call to sysctlbyname().
kmip2.cannot.import.NVE.key
- Severity
ALERT
- Description
This message occurs when the KMIP2 client cannot import an NVE key from a KMIP key server. A key was retrieved from a KMIP key server, but an error occurred when trying to add the key to an ONTAP® data structure.
- Corrective Action
- Syslog Message
KMIP2 client failed to import NVE key from KMIP key server, error: %d
- Parameters
kmip2.cannot.read.client.cert
- Severity
ALERT
- Description
This message occurs when the client certificate cannot be read. On a Cloud ONTAP® system, this message indicates one of the following: 1) A request to create an encrypted aggregate will not succeed because the key cannot be sent to the external KMIP server, or 2) The request to retrieve a key from the external KMIP server will fail. In this case, the encrypted aggregate will not be able to be mounted. On a NSE system, this message indicates one of the following: 1) A request to re-key a NSE drive will not succeed because the key cannot be sent to the external KMIP server, or 2) The ability to read/write data to/from a NSE drive might be impacted if power to the drive or to the disk shelf is lost.
- Corrective Action
Examine the KMIP client certificate and ensure that the certificate has been created properly.
- Syslog Message
KMIP Failed to read client certificate with error: %s
- Parameters
err (STRING): KMIP error code.
kmip2.cannot.read.private.key
- Severity
ALERT
- Description
This message occurs when the client private key certificate can't be read. On a Cloud ONTAP® system, this message indicates one of the following: 1) A request to create an encrypted aggregate will not succeed because the key cannot be sent to the external KMIP server, or 2) The request to retrieve a key from the external KMIP server will fail. In this case, the encrypted aggregate will not be able to be mounted. On a NSE system, this message indicates one of the following: 1) A request to re-key a NSE drive will not succeed because the key cannot be sent to the external KMIP server, or 2) The ability to read/write data to/from a NSE drive might be impacted if power to the drive or to the disk shelf is lost.
- Corrective Action
Examine the KMIP client private certificate and ensure that the certificate has been created properly.
- Syslog Message
KMIP Failed to read client private certificate with error: %s
- Parameters
