ONTAP EMS reference
monitor.mismatch events
monitor.mismatch EMS events occur when ONTAP encounters issues associated with hardware and software branding mismatches.
monitor.mismatch.hourly
Severity
ALERT
This message occurs when the version of ONTAP® is not supported on this hardware. You cannot run a version of ONTAP produced by one vendor on hardware supplied by another. The system will shut down if you do not install a correctly branded version of ONTAP.
Corrective Action
Install a correctly branded version of ONTAP before the timer expires.
Syslog Message
ONTAP detected a branding mismatch. The hardware is branded by %s and ONTAP is branded by %s. There are %d hour(s) left before shutdown. Install a version of ONTAP branded by your hardware vendor.
hardware (STRING): Vendor brand associated with the hardware.
software (STRING): Vendor brand associated with the version of ONTAP.
hours (INT): Number of hours before shutdown.
monitor.mismatch.shutdown
Severity
EMERGENCY
This message occurs when the system shuts down because the hardware brand does not match the ONTAP® version brand.
Corrective Action
Install a correctly branded version of ONTAP to prevent subsequent shutdowns for brand mismatch. Monitor the EMS_monitor_mismatch_hourly message to determine when the next shutdown will occur because of the brand mismatch.
Syslog Message
Shutting down because of a software branding mismatch. The hardware is branded by %s and ONTAP is branded by %s.
software (STRING): Vendor brand associated with the version. of ONTAP.
