monitor.mismatch events
Creating your file...
monitor.mismatch.hourly
- Severity
ALERT
- Description
This message occurs when the version of ONTAP® is not supported on this hardware. You cannot run a version of ONTAP produced by one vendor on hardware supplied by another. The system will shut down if you do not install a correctly branded version of ONTAP.
- Corrective Action
Install a correctly branded version of ONTAP before the timer expires.
- Syslog Message
ONTAP detected a branding mismatch. The hardware is branded by %s and ONTAP is branded by %s. There are %d hour(s) left before shutdown. Install a version of ONTAP branded by your hardware vendor.
- Parameters
hardware (STRING): Vendor brand associated with the hardware.
software (STRING): Vendor brand associated with the version of ONTAP.
hours (INT): Number of hours before shutdown.
monitor.mismatch.shutdown
- Severity
EMERGENCY
- Description
This message occurs when the system shuts down because the hardware brand does not match the ONTAP® version brand.
- Corrective Action
Install a correctly branded version of ONTAP to prevent subsequent shutdowns for brand mismatch. Monitor the EMS_monitor_mismatch_hourly message to determine when the next shutdown will occur because of the brand mismatch.
- Syslog Message
Shutting down because of a software branding mismatch. The hardware is branded by %s and ONTAP is branded by %s.
- Parameters
software (STRING): Vendor brand associated with the version. of ONTAP.
