air.removed events
air.removed EMS events occur when there is an inconsistency in the remote lock entry metafile.
air.removed.remote.lck.entry
- Severity
NOTICE
- Description
This message occurs when there is an inconsistency in the remote lock entry metafile. The inconsistent entry is removed upon detection.
- Corrective Action
(None).
- Syslog Message
Remote lock entry %s certification failed: expression %s, source %s, state (%s).
- Parameters
entry (STRING): Lock entry type and origin file ID pair describing the entry.
rlem (STRING): Describes the metafile to which this lock entry belongs to.
condition (STRING): Initial metadata validation test that failed.
source (STRING): Location of the failing metadata validation test.
state (STRING): Description of the remote lock entry metafile metadata state that was found to be inconsistent.
