ONTAP EMS reference
air.removed events
air.removed EMS events occur when there is an inconsistency in the remote lock entry metafile.
air.removed.remote.lck.entry
Severity
NOTICE
This message occurs when there is an inconsistency in the remote lock entry metafile. The inconsistent entry is removed upon detection.
Corrective Action
(None).
Syslog Message
Remote lock entry %s certification failed: expression %s, source %s, state (%s).
entry (STRING): Lock entry type and origin file ID pair describing the entry.
rlem (STRING): Describes the metafile to which this lock entry belongs to.
condition (STRING): Initial metadata validation test that failed.
source (STRING): Location of the failing metadata validation test.
state (STRING): Description of the remote lock entry metafile metadata state that was found to be inconsistent.
