The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
air.removed events
Creating your file...
Your file is ready
air.removed.remote.lck.entry
- Severity
NOTICE
- Description
This message occurs when there is an inconsistency in the remote lock entry metafile. The inconsistent entry is removed upon detection.
- Corrective Action
(None).
- Syslog Message
Remote lock entry %s certification failed: expression %s, source %s, state (%s).
- Parameters
entry (STRING): Lock entry type and origin file ID pair describing the entry.
rlem (STRING): Describes the metafile to which this lock entry belongs to.
condition (STRING): Initial metadata validation test that failed.
source (STRING): Location of the failing metadata validation test.
state (STRING): Description of the remote lock entry metafile metadata state that was found to be inconsistent.
