The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.cifsetcdmaxtxnlimit events
Creating your file...
Your file is ready
Nblade.cifsEtcdMaxTxnLimit
- Severity
ERROR
- Description
This message occurs when the number of Access Control Entries (ACE) present in an MSRPC request for updating share permissions exceeds the supported maximum etcd limit of 1,022 entries.
- Corrective Action
Retry the operation with less than the maximum supported number of ACEs in the MSRPC request.
- Syslog Message
Received an etcd failure event. Message is %s.
- Parameters
pMessage (STRING): Description of the error.
