ONTAP EMS reference
net.ipsconfig events
net.ipsconfig EMS events occur when creation of an IPspace fails.
net.ipsconfig.failed
Severity
ALERT
This message occurs when creation of an IPspace fails. This failure leaves the system with an unusable IPspace.
Corrective Action
Delete the IPspace reporting the failure by using the "ipspace delete" command. Use the (privilege: diag) "debug smdb table ipspaces_byname show" command to find the mapping from the ID reported in the event to the IPspace name required to delete this IPspace.
Syslog Message
IPspace (%d) needs to be deleted because configuration (%s) failed with error (%s).
ipsid (INT): IPspace ID.
configuration (STRING): Configuration attempted.
error (STRING): Error returned.
