      net.ipsconfig events
net.ipsconfig.failed
- Severity
ALERT
 - Description
This message occurs when creation of an IPspace fails. This failure leaves the system with an unusable IPspace.
 - Corrective Action
Delete the IPspace reporting the failure by using the "ipspace delete" command. Use the (privilege: diag) "debug smdb table ipspaces_byname show" command to find the mapping from the ID reported in the event to the IPspace name required to delete this IPspace.
 - Syslog Message
IPspace (%d) needs to be deleted because configuration (%s) failed with error (%s).
 - Parameters
ipsid (INT): IPspace ID.
configuration (STRING): Configuration attempted.
error (STRING): Error returned.
