The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
moveagent.dst events
Creating your file...
Your file is ready
moveagent.dst.partial.commit
- Severity
ALERT
- Description
This message occurs when the move agent detects that the attributes of the destination volume are partially updated during the commit destination phase. In such scenarios, the volume move operation may not be able to complete successfully and the client access will be blocked during this whole period.
- Corrective Action
Monitor the volume move job using the 'volume move show' command. If the problem presists, please contact NetApp technical support for recovery procedures.
- Syslog Message
Unable to finish the volume move operation as the destination volume with dsid:%llu and uuid:%s is partially committed.
- Parameters
volume_dsid (LONGINT): The destination volume data set identifier (dsid)
volume_uuid (STRING): The destination volume uuid.
