The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cf.fmns events
Creating your file...
Your file is ready
cf.fmns.skipped.disk
- Severity
NOTICE
- Description
This message occurs when a node is in "Waiting For Giveback" state and the Failover Monitor Node State (fmns)module skips a local disk while releasing the reservations in that state.
- Corrective Action
(None).
- Syslog Message
While releasing the reservations in "Waiting For Giveback" state Failover Monitor Node State(fmns) module skipped the disk %s that is owned by %u and reserved by %u.
- Parameters
uid_string (STRING): Name of the disk which was skipped by fmns.
down_owner (INT): The system ID of the node that owns this disk.
resvn_owner (INT): The system ID of the node that has a reservation on this disk.
