The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cecc_log.entry_no_syslog events
Creating your file...
Your file is ready
- Severity
NOTICE
- Description
Correctable ECC errors occurred in the system memory. The system automatically corrects these errors. All the corrected errors are reported by the ECC error logger to track the history of occurrence of these errors.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
cecc_entry_num (LONGINT): Number of correctable ECC errors since boot.
cecc_msg (STRING): Information about the ECC error.
