openssh.unsupported events
openssh.unsupported.cipher
Severity
ERROR
This message occurs when an unsupported cipher is used while attempting an SSH connection.
Corrective Action
Attempt to connect with SSH by using a supported cipher.
Syslog Message
Attempted an SSH connection using unsupported cipher %s.
ciphername (STRING): Cipher used for the SSH connection.
openssh.unsupported.hostalgo
Severity
ERROR
This message occurs when an unsupported host key algorithm is used while attempting an SSH connection.
Corrective Action
Attempt to connect with SSH by using a supported host key algorithm.
Syslog Message
SSH connection from %s was attempted using an unsupported host key algorithm %s.
ipaddress (STRING): IP address of the remote host that was trying to establish an SSH connection.
hostkeyalgorithm (STRING): Host key algorithm used for the SSH connection attempt.
openssh.unsupported.kexalgo
Severity
ERROR
This message occurs when an unsupported key exchange algorithm is used while attempting an SSH connection.
Corrective Action
Attempt to connect with SSH by using a supported key exchange algorithm.
Syslog Message
Attempted an SSH connection using unsupported key exchange algorithm %s.
kexalgorithm (STRING): Key exchange algorithm used for the SSH connection.
openssh.unsupported.MAC
Severity
ERROR
This message occurs when an unsupported Message Authentication Code (MAC) is used while attempting an SSH connection.
Corrective Action
Attempt to connect with SSH by using a supported MAC.
Syslog Message
Attempted an SSH connection using unsupported MAC %s.
macname (STRING): MAC used for the SSH connection.
