openssh.unsupported events
openssh.unsupported EMS events occur when ONTAP encounters issues associated with SSH connection attempts using unsupported parameters.
openssh.unsupported.cipher
- Severity
ERROR
- Description
This message occurs when an unsupported cipher is used while attempting an SSH connection.
- Corrective Action
Attempt to connect with SSH by using a supported cipher.
- Syslog Message
Attempted an SSH connection using unsupported cipher %s.
- Parameters
ciphername (STRING): Cipher used for the SSH connection.
openssh.unsupported.hostalgo
- Severity
ERROR
- Description
This message occurs when an unsupported host key algorithm is used while attempting an SSH connection.
- Corrective Action
Attempt to connect with SSH by using a supported host key algorithm.
- Syslog Message
SSH connection from %s was attempted using an unsupported host key algorithm %s.
- Parameters
ipaddress (STRING): IP address of the remote host that was trying to establish an SSH connection.
hostkeyalgorithm (STRING): Host key algorithm used for the SSH connection attempt.
openssh.unsupported.kexalgo
- Severity
ERROR
- Description
This message occurs when an unsupported key exchange algorithm is used while attempting an SSH connection.
- Corrective Action
Attempt to connect with SSH by using a supported key exchange algorithm.
- Syslog Message
Attempted an SSH connection using unsupported key exchange algorithm %s.
- Parameters
kexalgorithm (STRING): Key exchange algorithm used for the SSH connection.
openssh.unsupported.MAC
- Severity
ERROR
- Description
This message occurs when an unsupported Message Authentication Code (MAC) is used while attempting an SSH connection.
- Corrective Action
Attempt to connect with SSH by using a supported MAC.
- Syslog Message
Attempted an SSH connection using unsupported MAC %s.
- Parameters
macname (STRING): MAC used for the SSH connection.
