config.fcsameloop events
config.FCSameLoop
Severity
ERROR
This message occurs when a disk is multipathed to the same Fibre Channel loop.
Corrective Action
Recable the disk shelf containing the specified disk so that it is multipathed to different Fibre Channel loops.
Syslog Message
Disk %s is attached to the same Fibre Channel loop. The disk should be multipathed to different loops.
disk (STRING): Name of the disk.
