config.fcsameloop events
Creating your file...
Your file is ready
config.FCSameLoop
- Severity
ERROR
- Description
This message occurs when a disk is multipathed to the same Fibre Channel loop.
- Corrective Action
Recable the disk shelf containing the specified disk so that it is multipathed to different Fibre Channel loops.
- Syslog Message
Disk %s is attached to the same Fibre Channel loop. The disk should be multipathed to different loops.
- Parameters
disk (STRING): Name of the disk.
