The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.fcsameloop events
Creating your file...
Your file is ready
config.FCSameLoop
- Severity
ERROR
- Description
This message occurs when a disk is multipathed to the same Fibre Channel loop.
- Corrective Action
Recable the disk shelf containing the specified disk so that it is multipathed to different Fibre Channel loops.
- Syslog Message
Disk %s is attached to the same Fibre Channel loop. The disk should be multipathed to different loops.
- Parameters
disk (STRING): Name of the disk.
