The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cr.sync events
Creating your file...
Your file is ready
CR.Sync.ACL.Fail
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
NOTICE
- Description
This message occurs when an attempt to synchronize the ACL from data to redirector fails.
- Corrective Action
(None).
- Syslog Message
ACL synchronizing failed for file [%s] on volume [%s] in Vserver [%s].
- Parameters
path (STRING): Stream path.
volume (STRING): Name of the constituent volume where the file resides.
vserver (STRING): Vserver hosting the volume.
