ONTAP EMS reference
config.nomultipath events
config.NoMultiPath
Severity
ALERT
This message occurs when a disk is found with multiple paths and it does not support them.
Corrective Action
Remove the second path from the disk shelf.
Syslog Message
Disk %s cannot be multipathed.
disk (STRING): Name of the disk that was found.
