config.nomultipath events
Creating your file...
Your file is ready
config.NoMultiPath
- Severity
ALERT
- Description
This message occurs when a disk is found with multiple paths and it does not support them.
- Corrective Action
Remove the second path from the disk shelf.
- Syslog Message
Disk %s cannot be multipathed.
- Parameters
disk (STRING): Name of the disk that was found.
