      coredump.mcc events
coredump.mcc.nso.veto
- Severity
INFORMATIONAL
 - Description
This message occurs when the coredump subsystem vetoes MetroCluster(tm) negotiated switchover because a coredump save is in progress.
 - Corrective Action
Use the "node coredump status" command to verify the completion of the active coredump save, or use the "-override-vetoes true" option when performing MetroCluster switchover. Using the "-override-vetoes true" option will abort the active coredump save.
 - Syslog Message
MetroCluster switchover vetoed because a coredump save was in progress.
 - Parameters
(None).
