coredump.mcc events
coredump.mcc.nso.veto
- Severity
INFORMATIONAL
- Description
This message occurs when the coredump subsystem vetoes MetroCluster(tm) negotiated switchover because a coredump save is in progress.
- Corrective Action
Use the "node coredump status" command to verify the completion of the active coredump save, or use the "-override-vetoes true" option when performing MetroCluster switchover. Using the "-override-vetoes true" option will abort the active coredump save.
- Syslog Message
MetroCluster switchover vetoed because a coredump save was in progress.
- Parameters
(None).
