The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ztl.smap events
Creating your file...
Your file is ready
ztl.smap.online.status
- Severity
NOTICE
- Description
This message occurs when the specified partition on a SSD-ZNS drive could not be onlined due to internal S/W or device error.
- Corrective Action
(None).
- Syslog Message
Disk %s partition %d (first zone=%d, number of zones=%d) online operation failed. HBA status: %d, NVMe status (type: %d, code: %d).
- Parameters
disk (STRING): Disk name.
partition (INT): SMap Partition number.
start_zone (INT): SMAP start logical zone.
num_zones (INT): Number of logical zones in the SMAP instance.
ha_err_status (INT): Host Adapter error status.
nvme_err_code_type (INT): NVME error code type.
nvme_err_code (INT): NVME error for the specific NVME error code type.
