The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sp.reboot events
Creating your file...
Your file is ready
sp.reboot.ro.partition
- Severity
NOTICE
- Description
This message occurs when the node's Service Processor (SP) or Baseboard Management Controller (BMC) log partition is mounted as read-only after an internal error has occurred. The system automatically reboots the SP or BMC to attempt to remount the log partition as read-write.
- Corrective Action
(None).
- Syslog Message
Rebooting the %s because the log partition is in a read-only state.
- Parameters
sp_type (STRING): Service processor type (SP or BMC)
sp.reboot.sensor.unreadable
- Severity
NOTICE
- Description
This message occurs when one or more sensors are unreadable from Service Processor (SP) or Baseboard Management Controller (BMC).SP or BMC is rebooted in attempt to recover the sensor reading.
- Corrective Action
No user action is required.
- Syslog Message
Rebooting %s because one or more sensors are unreadable.
- Parameters
sp_type (STRING): Service processor type (SP or BMC).
