The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
command.complex events
Creating your file...
Your file is ready
command.complex.query
- Severity
ERROR
- Description
This message occurs when a custom role associated with a Storage Virtual Machine has a command directory with complex query.
- Corrective Action
Remove the complex query. See BUG 915877 for more information.
- Syslog Message
The %s command directory in %s role under Storage Virtual Machine %s, will not be available in merged role.
- Parameters
vserver (STRING): Name of the Storage Virtual Machine.
rolename (STRING): Name of the role associated with the Virtual Storage Machine, with a command directory with a complex query.
cmddirname (STRING): Name of the command directory with complex query.
