The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netif.sfpnotsupported events
Creating your file...
Your file is ready
netif.sfpNotSupported
- Severity
ERROR
- Description
This message occurs when the installed Small Form-factor Pluggable (SFP+ or QSFP+) module is not supported.
- Corrective Action
Replace the SFP+ or QSFP+ module with one purchased from NetApp for this interface.
- Syslog Message
The SFP+ or QSFP+ module (%s %s) installed in %s is not supported with this network interface.
- Parameters
sfpVendor (STRING): SFP+ or QSFP+ vendor name.
sfpPn (STRING): SFP+ or QSFP+ part number.
ifName (STRING): Name of the network interface; for example, "e2a".
