The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
monitor.chassisfanfail events
Creating your file...
Your file is ready
monitor.chassisFanFail.xMinShutdown
- Severity
EMERGENCY
- Description
This message occurs when multiple chassis fans have failed, and the system will shut down in a few minutes unless corrected.
- Corrective Action
Reseat the chassis fans. If they do not restart, replace them.
- Syslog Message
Multiple Chassis Fan failure: System will shut down in %d minutes.
- Parameters
num_minutes (INT): Number of minutes until the system will shut down.
