ONTAP EMS reference
monitor.chassisfanfail events
monitor.chassisfanfail EMS events occur when multiple chassis fans have failed, and the system will shut down in a few minutes unless corrected.
monitor.chassisFanFail.xMinShutdown
Severity
EMERGENCY
This message occurs when multiple chassis fans have failed, and the system will shut down in a few minutes unless corrected.
Corrective Action
Reseat the chassis fans. If they do not restart, replace them.
Syslog Message
Multiple Chassis Fan failure: System will shut down in %d minutes.
num_minutes (INT): Number of minutes until the system will shut down.
