ONTAP EMS reference
volcmd.snapmirror events
volcmd.snapmirror.removed
Severity
ERROR
This mesage occurs to advise you that the 'vol snapmirror' set of commands has been removed.
Corrective Action
Use the 'snapmirror' command instead.
Syslog Message
The 'vol snapmirror' set of commands has been removed; use the 'snapmirror' command instead.
(None).
