volcmd.snapmirror events
Creating your file...
Your file is ready
volcmd.snapmirror.removed
- Severity
ERROR
- Description
This mesage occurs to advise you that the 'vol snapmirror' set of commands has been removed.
- Corrective Action
Use the 'snapmirror' command instead.
- Syslog Message
The 'vol snapmirror' set of commands has been removed; use the 'snapmirror' command instead.
- Parameters
(None).
