fmmb.destroy events
Creating your file...
Your file is ready
fmmb.destroy.mbx
- Severity
INFORMATIONAL
- Description
This event is issued when the high-availability (HA) Mailbox contents are cleared, typically by the 'mailbox destroy' command.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
disk_name (STRING): Disk name on which the mailbox was cleared.
fmmb.destroy.mbx.fail
- Severity
NOTICE
- Description
This event is issued when an attempt is made to destroy the mailbox contents on the disk and this fails. Data ONTAP to a 7.0 or later version.
- Corrective Action
(None).
- Syslog Message
Failed to clear mailbox on disk:%s, error:%s.
- Parameters
disk_name (STRING): disk name on which we are trying to clear the mailbox.
error (STRING): The reason why mailbox clear failed.
