ONTAP EMS reference
fmmb.destroy events
fmmb.destroy EMS events occur when ONTAP encounters issues associated with high-availability (HA) Mailbox destruction.
fmmb.destroy.mbx
Severity
INFORMATIONAL
This event is issued when the high-availability (HA) Mailbox contents are cleared, typically by the 'mailbox destroy' command.
Corrective Action
(None).
Syslog Message
(None).
disk_name (STRING): Disk name on which the mailbox was cleared.
fmmb.destroy.mbx.fail
Severity
NOTICE
This event is issued when an attempt is made to destroy the mailbox contents on the disk and this fails. Data ONTAP to a 7.0 or later version.
Corrective Action
(None).
Syslog Message
Failed to clear mailbox on disk:%s, error:%s.
disk_name (STRING): disk name on which we are trying to clear the mailbox.
error (STRING): The reason why mailbox clear failed.
