ONTAP EMS reference
monitor.iocard events
monitor.iocard EMS events occur when ONTAP encounters issues associated with I/O card operation.
monitor.ioCard.degraded
Severity
ALERT
This message indicates that an I/O card is degraded.
Corrective Action
Exchange or replace the card with a known good card in the same I/O slot. If the problem persists, contact NetApp technical support for replacement assistance.
Syslog Message
IO card is degraded: %s
reasonText (STRING): Slot number of the card and the reason the card is degraded.
monitor.ioCard.ok
Severity
NOTICE
This message indicates that an I/O card is operating properly.
Corrective Action
None.
Syslog Message
IO card on slot %d is OK
slot_number (INT): Slot number of the card.
