nblade.vscannodispatcher events
Creating your file...
Your file is ready
Nblade.vscanNoDispatcher
- Severity
ALERT
- Description
This message occurs when the vscan-dispatcher component cannot be created. This might be due to internal errors on the system, such as nonavailability of memory. This might cause data unavailability if the scan-mandatory option is enabled.
- Corrective Action
Disable Vscan and enable it again by using the "vserver vscan disable/enable" command. If the problem persists, contact NetApp technical support.
- Syslog Message
Vscan dispatcher component for Vserver "%s" could not be created. Error: %d.
- Parameters
vserverName (STRING): Vserver associated with this operation.
errorCode (INT): Error code that describes the reason for the failure.
