nblade.vscannodispatcher events
Nblade.vscanNoDispatcher
Severity
ALERT
This message occurs when the vscan-dispatcher component cannot be created. This might be due to internal errors on the system, such as nonavailability of memory. This might cause data unavailability if the scan-mandatory option is enabled.
Corrective Action
Disable Vscan and enable it again by using the "vserver vscan disable/enable" command. If the problem persists, contact NetApp technical support.
Syslog Message
Vscan dispatcher component for Vserver "%s" could not be created. Error: %d.
vserverName (STRING): Vserver associated with this operation.
errorCode (INT): Error code that describes the reason for the failure.
