rshd.failure events
rshd.failure
Severity
ERROR
This event is generated after rshd failed to start.
Corrective Action
Restart the rsh daemon for the affected vfiler by using the vfiler run command to set the rsh.enable option to off and then to on for that vfiler.
Syslog Message
rshd failed to start for vfiler %s
vfilername (STRING): The name of the vfiler that attempted to start rshd
