rshd.failure events
rshd.failure
- Severity
ERROR
- Description
This event is generated after rshd failed to start.
- Corrective Action
Restart the rsh daemon for the affected vfiler by using the vfiler run command to set the rsh.enable option to off and then to on for that vfiler.
- Syslog Message
rshd failed to start for vfiler %s
- Parameters
vfilername (STRING): The name of the vfiler that attempted to start rshd
