ONTAP EMS reference
dbs.ssl events
dbs.ssl EMS events occur when the Distributed Block Store (DBS) detects that a Secure Socket Layer (SSL) certificate on a node is nearing expiration.
dbs.ssl.node.cert.expire
Severity
NOTICE
This message occurs when Distributed Block Store (DBS) detects that a Secure Socket Layer (SSL) certificate on a node is nearing expiration. No action is needed. The system resolves this issue by automatically updating the certificate.
Corrective Action
(None).
Syslog Message
DBS has detected that an SSL certificate is nearing expiration. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node universal unique identifier (UUID) string of the associated node.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Details of the certificates that are nearing expiration.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the "CreateClusterFault" API command and attached to the fault for testing purposes.
