sis.compress events
Creating your file...
Your file is ready
sis.compress.skip
- Severity
INFORMATIONAL
- Description
This message occurs when postprocess compression is skipped during a deduplication operation, even though postprocess compression is enabled on the volume. Post process compression is not supported on a node configured with the All-Flash Optimized personality.
- Corrective Action
(None).
- Syslog Message
Skipped postprocess compression on volume %s%s because the node is All-Flash Optimized.
- Parameters
path (STRING): Path to the deduplicated volume.
volident (STRING): Unique volume identifier.
