xfcvi.disabled events
xfcvi.disabled EMS events occur when the HA interconnect card is disabled by the ic-type environment variable.
xfcvi.disabled
- Severity
ALERT
- Description
This message occurs when the HA interconnect card is disabled by the ic-type environment variable.
- Corrective Action
Either remove the HA interconnect card from the controller or change the ic-type environment variable.
- Syslog Message
FC-VI adapter: Port %s has been disabled because of the ic-type environment variable.
- Parameters
port (STRING): xfcvi Interconnect NIC.
