ONTAP EMS reference
nblade.vscanbaduserprivaccess events
nblade.vscanbaduserprivaccess EMS events occur during a client attempt to connect to the privileged ONTAP_ADMIN$ share, when the logged-in user of that client is not found in the list of allowed users.
Nblade.vscanBadUserPrivAccess
Severity
ERROR
This message occurs during a client attempt to connect to the privileged ONTAP_ADMIN$ share, when the logged-in user of that client is not found in the list of allowed users.
Corrective Action
Ensure that the mentioned user name and IP address is configured in one of the active vscan scanner pools. Use the "vserver vscan scanner pool show-active" command to view the currently active scanner pool configuration.
Syslog Message
For Vserver "%s", the attempt to connect to the privileged ONTAP_ADMIN$ share by the client "%s" is rejected because its logged-in user "%s" is not configured in any of the Vserver active scanner pools.
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the client.
userName (STRING): Logged-in user of the client.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
