The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
disk.encryptnosupport events
Creating your file...
Your file is ready
disk.encryptNoSupport
- Severity
ALERT
- Description
This message occurs when ONTAP® software detects one or more FIPS-certified self-encrypting drives, but the environment variable 'bootarg.storageencryption.support' is not present or is set to "false" to indicate that FIPS-certified drives are not supported.
- Corrective Action
Remove all FIPS-certified drives.
- Syslog Message
Detected FIPS-certified encrypting drive %s, but FIPS drives are not supported on this node. %d of %d disks checked are FIPS-certified.
- Parameters
disk (STRING): Name of a FIPS-certified drive.
FIPS_disks (INT): Number of FIPS-certified drives detected.
disk_count (INT): Total number of drives checked. For a high-availability pair, this might be fewer than the total number of drives.
