connectx.ibqsfpdumpdata events
connectx.IbQsfpDumpData
Severity
ERROR
This message occurs when InfiniBand retimer programming fails due to a quad small form-factor pluggable (QSFP) transceiver parse error, and 128 bytes of QSFP data are dumped.
Corrective Action
Automatic retry of InfiniBand retimer programming will be done and an AutoSupport(tm) message will be generated if two retries fail.
Syslog Message
InfiniBand retimer programming failed on port %s due to %s. Dumping registers: %s.
port_str (STRING): InfiniBand port in which the cable is plugged.
reason (STRING): Reason for the failure of InfiniBand retimer programming.
qsfp_data (STRING): Contents of QSFP data registers from offset 128 to 256 in hexadecimal notation.
