connectx.ibqsfpdumpdata events
connectx.IbQsfpDumpData
- Severity
ERROR
- Description
This message occurs when InfiniBand retimer programming fails due to a quad small form-factor pluggable (QSFP) transceiver parse error, and 128 bytes of QSFP data are dumped.
- Corrective Action
Automatic retry of InfiniBand retimer programming will be done and an AutoSupport(tm) message will be generated if two retries fail.
- Syslog Message
InfiniBand retimer programming failed on port %s due to %s. Dumping registers: %s.
- Parameters
port_str (STRING): InfiniBand port in which the cable is plugged.
reason (STRING): Reason for the failure of InfiniBand retimer programming.
qsfp_data (STRING): Contents of QSFP data registers from offset 128 to 256 in hexadecimal notation.
