wafl.inconsistent events
wafl.inconsistent.acl
- Severity
ERROR
 - Description
This message occurs when the ONTAP® kernel detects an inconsistent WAFL® Access Control List (ACL) on disk. Access to this ACL is disabled until you repair it by running wafliron.
 - Corrective Action
Contact NetApp technical support.
 - Syslog Message
WAFL inconsistent: bad ACL (xfileid:%u snapid:%u) for inode (fileid:%u) in volume %s%s%s%s.
 - Parameters
xfileid (INT): Identifying number for the suspect ACL.
snapid (INT): Snapshot(tm) copy identifier (0) - active file system (non-zero) - refers to Snapshot copy.
fileid (INT): Identifying number for the inode.
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.inconsistent.acl.data
- Severity
ERROR
 - Description
This message occurs when Data ONTAP detects inconsistent Access Control List (ACL) data on disk.
 - Corrective Action
The volume has inconsistent Access Control List (ACL) data. Use the "volume file show-inode" command with the file ID and volume name information to find the file path. .Rebuild ACL for the file.
 - Syslog Message
WAFL inconsistent: bad ACL data (acl_fileid:%u acl_snapid:%u) for inode (fileid:%u snapid:%u file_type:%d disk_flags:0x%x) in volume %s%s%s%s%s.
 - Parameters
acl_fileid (INT): Identifying number for the ACL inode
acl_snapid (INT): Snapshot(tm) copy identifier for ACL inode: (0) - active file system (non-zero) - refers to Snapshot copy
fileid (INT): Identifying number for the inode that owns the ACL.
snapid (INT): Snapshot(tm) copy identifier: (0) - active file system (non-zero) - refers to Snapshot copy
type (INT): File type.
flags (LONGINT): Inode disk flags.
volident (STRING): Uniquely identifies the volume when the volume name itself is insufficient.
inotype (STRING): The inode space (public or private)
wafl.inconsistent.compacted.block
- Severity
NOTICE
 - Description
This message occurs when an inconsistency is detected in a compacted block.
 - Corrective Action
(None).
 - Syslog Message
Inconsistent compacted block %llu in %s "%s". %s
 - Parameters
pvbn (LONGINT): Volume block number.
volume_identifier (STRING): Volume identifier.
volume (STRING): Volume name.
message (STRING): Type of inconsistency in compacted block.
wafl.inconsistent.container
- Severity
ERROR
 - Description
This message occurs when the WAFL® kernel detects a block in a FlexVol® volume that is inaccessible. Access to this block is disabled until you repair it by running wafliron.
 - Corrective Action
The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency. For a SnapMirror® target, rebuild from the source or resynchronize. If the inode is in a Snapshot(tm) copy, delete the Snapshot copy, then contact NetApp technical support.
 - Syslog Message
WAFL inconsistent: Volume %s%s%s%s has unreachable block at vvbn %llu (pvbn %llu).
 - Parameters
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
vvbn (LONGINT): Virtual block number.
pvbn (LONGINT): Physical block number.
wafl.inconsistent.dir
- Severity
ALERT
 - Description
This event occurs when the WAFL® kernel detects an inconsistent directory on disk. Access to this directory is disabled until you repair it by running wafliron.
 - Corrective Action
The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency; for a snapmirror target, rebuild from source or resync or if inode is in a snapshot, delete the snapshot. Then contact NetApp technical support.
 - Syslog Message
WAFL inconsistent: %s: bad directory ( %s fileid:%u, snapid: %u, type:%u, size:%u) in volume %s%s%s%s.
 - Parameters
func (STRING): The internal function name
ino_type (STRING): The inode type
fileid (INT): The identifying number for the suspect inode
snapid (INT): Snapshot identifier (0) - active file system (non-zero) - refers to snapshot
type (INT): The type of inode that's supposed to be a directory of some type
size (INT): The possibly corrupt size of the suspect inode.
owner (STRING): The owner of the volume
vol (STRING): The name of the volume
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.inconsistent.dirent
- Severity
EMERGENCY
 - Description
This event occurs when an inconsistent directory entry has been detected. Access to this directory entry is disabled.
 - Corrective Action
If this error condition occurs, contact NetApp technical support for further assistance.
 - Syslog Message
WAFL inconsistent: %s: bad entry {x%x %d snapid: %d %d %d} <%.*s> in %s directory {x%x %d snapid: %d %d %d} in volume %s%s%s%s.
 - Parameters
fh0 (INT): fh[0]
fh1 (INT): fh[1] - snapid (0) - active file system (non-zero) - refers to snapshot
fh2 (INT): fh[2]
fh3 (INT): fh[3]
fh4 (INT): fh[4]
name (STRINGARRAY): The name of the directory entry
dfh0 (INT): dfh[0]
dfh1 (INT): dfh[1] - snapid in filehandle (0) - active file system (non-zero) - refers to snapshot
dfh2 (INT): dfh[2]
dfh3 (INT): dfh[3]
dfh4 (INT): dfh[4]
wafl.inconsistent.ino
- Severity
ERROR
 - Description
This message occurs when the ONTAP® kernel detects an inconsistent inode on disk. Access to this inode is disabled until you repair it by running wafliron.
 - Corrective Action
 - Syslog Message
WAFL inconsistent: %s: bad inode (%s fileid: %u snapid: %u) in volume %s%s%s%s.
 - Parameters
func (STRING): Internal function name.
ino_type (STRING): Inode type.
fileid (INT): Identifying number for the suspect inode.
wafl.inconsistent.ino.tid
- Severity
ERROR
 - Description
This message occurs when the WAFL® kernel detects an inconsistent inode on a disk with a bad qtree ID.
 - Corrective Action
Use the "volume file show-inode" command with the file ID and volume name information to find the file path. The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency. For a SnapMirror target, rebuild from the source or resynchronize. If the inode is in a Snapshot copy, delete the Snapshot copy. Then contact technical support.
 - Syslog Message
WAFL inconsistent: bad qtree ID in inode (fileid:%u snapid:%u) in volume %s%s. Turning quotas off on the volume.
 - Parameters
wafl.inconsistent.snapshot
- Severity
ERROR
 - Description
This event occurs when the WAFL kernel discovers that a snapshot has either an invalid inofile, fsinfo, or snapmap file, or the snapshot vbn stored is invalid.
 - Corrective Action
Delete the snapshot. For a snapmirror target, rebuild from source or resync.
 - Syslog Message
WAFL inconsistent: deleting bad snapshot in volume %s%s%s%s, snapid %d, reason: %s
 - Parameters
snapid (INT): The snapshot identifier
reason (STRING): The reason the snapshot is bad
wafl.inconsistent.stream
- Severity
ERROR
 - Description
This event occurs when the WAFL® kernel detects an inconsistent stream information on disk. Access to the stream is disabled until you repair it by running wafliron.
 - Corrective Action
Use the "volume file show-inode" command with the file ID and volume name information to find the file path. The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency; for a snapmirror target, rebuild from source or resync or if the inode is in a snapshot, delete the snapshot. Then contact NetApp technical support.
 - Syslog Message
WAFL inconsistent: bad stream (sfileid:%u snapid: %u) for inode (fileid:%u) in volume %s%s%s%s.
 - Parameters
sfileid (INT): The identifying number for the suspect stream
fileid (INT): The identifying number for the inode
wafl.inconsistent.threshold.reached
- Severity
EMERGENCY
 - Description
This event occurs when the number of inconsistencies the WAFL® kernel detected and avoided reached the threshold.
 - Corrective Action
 - Syslog Message
WAFL inconsistent: The threshold for number of %s inconsistencies was reached. Volume %s %s%s%s%s will be taken offline. Contact NetApp technical support.
 - Parameters
reason (STRING): Reason : snapshot/inode/block
type (STRING): The container type (volume / aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
vendor (STRING): The vendor name
wafl.inconsistent.vol
- Severity
ERROR
 - Description
This event occurs when the WAFL® kernel discovers an inconsistent volume.
 - Corrective Action
The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency; For a SnapMirror® target, rebuild from source or resynchronize. If the inode is in a Snapshot copy, delete the Snapshot copy. Then contact NetApp technical support.
 - Syslog Message
WAFL inconsistent: %s %s%s%s%s is inconsistent. Note: Any new Snapshot copies might contain this inconsistency.
 - Parameters
wafl.inconsistent.vol.nomnt
- Severity
ERROR
 - Description
This message occurs when the ONTAP® kernel discovers an inconsistent volume and determines that the volume should not be mounted.
 - Corrective Action
 - Syslog Message
%s %s%s is not mounted.
 - Parameters
type (STRING): Container type (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
