ONTAP EMS reference
wafl.inconsistent events
wafl.inconsistent EMS events occur when ONTAP encounters issues associated with WAFL® file system consistency.
wafl.inconsistent.acl
Severity
ERROR
This message occurs when the ONTAP® kernel detects an inconsistent WAFL® Access Control List (ACL) on disk. Access to this ACL is disabled until you repair it by running wafliron.
Corrective Action
Contact NetApp technical support.
Syslog Message
WAFL inconsistent: bad ACL (xfileid:%u snapid:%u) for inode (fileid:%u) in volume %s%s%s%s.
xfileid (INT): Identifying number for the suspect ACL.
snapid (INT): Snapshot(tm) copy identifier (0) - active file system (non-zero) - refers to Snapshot copy.
fileid (INT): Identifying number for the inode.
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.inconsistent.acl.data
Severity
ERROR
This message occurs when Data ONTAP detects inconsistent Access Control List (ACL) data on disk.
Corrective Action
The volume has inconsistent Access Control List (ACL) data. Use the "volume file show-inode" command with the file ID and volume name information to find the file path. .Rebuild ACL for the file.
Syslog Message
WAFL inconsistent: bad ACL data (acl_fileid:%u acl_snapid:%u) for inode (fileid:%u snapid:%u file_type:%d disk_flags:0x%x) in volume %s%s%s%s%s.
acl_fileid (INT): Identifying number for the ACL inode
acl_snapid (INT): Snapshot(tm) copy identifier for ACL inode: (0) - active file system (non-zero) - refers to Snapshot copy
fileid (INT): Identifying number for the inode that owns the ACL.
snapid (INT): Snapshot(tm) copy identifier: (0) - active file system (non-zero) - refers to Snapshot copy
type (INT): File type.
flags (LONGINT): Inode disk flags.
volident (STRING): Uniquely identifies the volume when the volume name itself is insufficient.
inotype (STRING): The inode space (public or private)
wafl.inconsistent.compacted.block
Severity
NOTICE
This message occurs when an inconsistency is detected in a compacted block.
Corrective Action
(None).
Syslog Message
Inconsistent compacted block %llu in %s "%s". %s
pvbn (LONGINT): Volume block number.
volume_identifier (STRING): Volume identifier.
volume (STRING): Volume name.
message (STRING): Type of inconsistency in compacted block.
wafl.inconsistent.container
Severity
ERROR
This message occurs when the WAFL® kernel detects a block in a FlexVol® volume that is inaccessible. Access to this block is disabled until you repair it by running wafliron.
Corrective Action
The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency. For a SnapMirror® target, rebuild from the source or resynchronize. If the inode is in a Snapshot(tm) copy, delete the Snapshot copy, then contact NetApp technical support.
Syslog Message
WAFL inconsistent: Volume %s%s%s%s has unreachable block at vvbn %llu (pvbn %llu).
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
vvbn (LONGINT): Virtual block number.
pvbn (LONGINT): Physical block number.
wafl.inconsistent.dir
Severity
ALERT
This event occurs when the WAFL® kernel detects an inconsistent directory on disk. Access to this directory is disabled until you repair it by running wafliron.
Corrective Action
The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency; for a snapmirror target, rebuild from source or resync or if inode is in a snapshot, delete the snapshot. Then contact NetApp technical support.
Syslog Message
WAFL inconsistent: %s: bad directory ( %s fileid:%u, snapid: %u, type:%u, size:%u) in volume %s%s%s%s.
func (STRING): The internal function name
ino_type (STRING): The inode type
fileid (INT): The identifying number for the suspect inode
snapid (INT): Snapshot identifier (0) - active file system (non-zero) - refers to snapshot
type (INT): The type of inode that's supposed to be a directory of some type
size (INT): The possibly corrupt size of the suspect inode.
owner (STRING): The owner of the volume
vol (STRING): The name of the volume
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.inconsistent.dirent
Severity
EMERGENCY
This event occurs when an inconsistent directory entry has been detected. Access to this directory entry is disabled.
Corrective Action
If this error condition occurs, contact NetApp technical support for further assistance.
Syslog Message
WAFL inconsistent: %s: bad entry {x%x %d snapid: %d %d %d} <%.*s> in %s directory {x%x %d snapid: %d %d %d} in volume %s%s%s%s.
fh0 (INT): fh[0]
fh1 (INT): fh[1] - snapid (0) - active file system (non-zero) - refers to snapshot
fh2 (INT): fh[2]
fh3 (INT): fh[3]
fh4 (INT): fh[4]
name (STRINGARRAY): The name of the directory entry
dfh0 (INT): dfh[0]
dfh1 (INT): dfh[1] - snapid in filehandle (0) - active file system (non-zero) - refers to snapshot
dfh2 (INT): dfh[2]
dfh3 (INT): dfh[3]
dfh4 (INT): dfh[4]
wafl.inconsistent.ino
Severity
ERROR
This message occurs when the ONTAP® kernel detects an inconsistent inode on disk. Access to this inode is disabled until you repair it by running wafliron.
Corrective Action
Syslog Message
WAFL inconsistent: %s: bad inode (%s fileid: %u snapid: %u) in volume %s%s%s%s.
func (STRING): Internal function name.
ino_type (STRING): Inode type.
fileid (INT): Identifying number for the suspect inode.
wafl.inconsistent.ino.tid
Severity
ERROR
This message occurs when the WAFL® kernel detects an inconsistent inode on a disk with a bad qtree ID.
Corrective Action
Use the "volume file show-inode" command with the file ID and volume name information to find the file path. The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency. For a SnapMirror target, rebuild from the source or resynchronize. If the inode is in a Snapshot copy, delete the Snapshot copy. Then contact technical support.
Syslog Message
WAFL inconsistent: bad qtree ID in inode (fileid:%u snapid:%u) in volume %s%s. Turning quotas off on the volume.
wafl.inconsistent.snapshot
Severity
ERROR
This event occurs when the WAFL kernel discovers that a snapshot has either an invalid inofile, fsinfo, or snapmap file, or the snapshot vbn stored is invalid.
Corrective Action
Delete the snapshot. For a snapmirror target, rebuild from source or resync.
Syslog Message
WAFL inconsistent: deleting bad snapshot in volume %s%s%s%s, snapid %d, reason: %s
snapid (INT): The snapshot identifier
reason (STRING): The reason the snapshot is bad
wafl.inconsistent.stream
Severity
ERROR
This event occurs when the WAFL® kernel detects an inconsistent stream information on disk. Access to the stream is disabled until you repair it by running wafliron.
Corrective Action
Use the "volume file show-inode" command with the file ID and volume name information to find the file path. The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency; for a snapmirror target, rebuild from source or resync or if the inode is in a snapshot, delete the snapshot. Then contact NetApp technical support.
Syslog Message
WAFL inconsistent: bad stream (sfileid:%u snapid: %u) for inode (fileid:%u) in volume %s%s%s%s.
sfileid (INT): The identifying number for the suspect stream
fileid (INT): The identifying number for the inode
wafl.inconsistent.threshold.reached
Severity
EMERGENCY
This event occurs when the number of inconsistencies the WAFL® kernel detected and avoided reached the threshold.
Corrective Action
Syslog Message
WAFL inconsistent: The threshold for number of %s inconsistencies was reached. Volume %s %s%s%s%s will be taken offline. Contact NetApp technical support.
reason (STRING): Reason : snapshot/inode/block
type (STRING): The container type (volume / aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
vendor (STRING): The vendor name
wafl.inconsistent.vol
Severity
ERROR
This event occurs when the WAFL® kernel discovers an inconsistent volume.
Corrective Action
The volume is inconsistent. Run wafliron as soon as possible to clear this inconsistency; For a SnapMirror® target, rebuild from source or resynchronize. If the inode is in a Snapshot copy, delete the Snapshot copy. Then contact NetApp technical support.
Syslog Message
WAFL inconsistent: %s %s%s%s%s is inconsistent. Note: Any new Snapshot copies might contain this inconsistency.
wafl.inconsistent.vol.nomnt
Severity
ERROR
This message occurs when the ONTAP® kernel discovers an inconsistent volume and determines that the volume should not be mounted.
Corrective Action
Syslog Message
%s %s%s is not mounted.
type (STRING): Container type (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
